Fields form selected record bold in tabular form
Hello, Can someone help me with the following? I’ve created a tabular form with only one field. The line which has the focus schould be shown bold. I tried using UPDATEFONTBOLD but either all or non of the records appear in bold. Best regards , Marcel
If e.g. you are using Customer you can do like this: First, declare a variable: coCurrNo, Code 20 Then in OnAfterGetCurrRecord type: coCurrNo := “No.” In the controls OnFormat type: CurrForm.“No.”.UPDATEFONTBOLD(“No.” = coCurrNo); And in the controls OnActivate (or OnDeActivate) type: CurrForm.UPDATE; This can be used for tables that have a single field as first key.
Thanx, This works fine! Marcel
