Field values in Project
Hi, new to Dynamics AX and had a question. The projects form, on the general tab, shows a responcibility section. In that, you can identify who the sales or project manager is. My question is this: Our system shows a number for that value and not a name. Is there a way to show the name instead? I am an end user. If that cant be done, how can I add a column in the grid view to show the name too? I am learning a lot about the system, but need this to be corrected badly, as the users might revolt on me!!! [:O]
Your help is greatly appreciated.
Hi Mike,
You can override the “Look up” method for these fields in the ProjTable Form Data source.
For Example :
public void lookup(FormControl _formControl, str _filterStr)
SysTableLookup sysTableLookup;
Query query = new Query();
QueryBuildDataSource qdb;
QueryBuildRange queryBuildRange;
qdb = query.addDataSource(tablenum(Tablename));
sysTableLookup = SysTableLookup::newParameters(tablenum(Tablename), _formControl);
// Keep on adding whatever fields you want to come in the grid
sysTableLookup.addLookupfield(fieldnum(Tablename,Fieldname1));
sysTableLookup.addLookupfield(fieldnum(Tablename,Fieldname2));
// Add a Range if required.
queryBuildRange = qdb.addRange(fieldnum(Tablename, Field));
queryBuildRange.value(queryvalue(Value));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
