Currently i am working on Navision 2009 (SP I). When Customizing a page i want to adjust the field size on the page. There is no option in property of that field. How can i adjust the size of that field.
Himanshu Kumar
Himanshu Kumar
Change the lenght of the field in the corresponding table. If it’s the width of a column in a grid - you can change that in the UI
Hi Torels,
The data type of the field is Option (Won,Loose). Then how can i adjust the lenght of that field. Is there any solution to adjust the field size on page.
Himanshu Kumar
Seems that option (adjust the field size) is not there, as properties like XPox,YPos, Width and height are not there in the case of page.
