Has anyone got a field renumbering tool to share ? tarek_demiati@ureach.com
Well for this tedious job we had to rename the fields in text files then re-import the entire thing, compile and fix a few screwed-up Calcformula and keys. If someone has renumbering tool to share please upload it in the NF tool section here, this will save a lot of frustrating hours to anyone who will have a field renumbering job in the future. tarek_demiati@ureach.com
Tarek was you was renaming rather than renumbering? you could have filtered @Job & dataported the fields Table record fields opened in anothe app then find and replace the text then import back in. You would still have had the same issues with the calcfields though. If not then the text output is the only way i know. David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk Edited by - David Cox on 2001 Apr 20 08:31:09
quote:
Originally posted by David Cox: Tarek was you was renaming rather than renumbering?
Hi Dave, I did renumber the field ID … it would be nice if Navision A/S integrates a field renumbering tool to their Object renumbering tool set. tarek_demiati@ureach.com
To renumber a field start by exporting all related objects as text. Renumber the field and import the exported objects and compile them. All relations, code, flowfields etc. will be intact.
quote:
Originally posted by tommyolesen: To renumber a field start by exporting all related objects as text. Renumber the field and import the exported objects and compile them. All relations, code, flowfields etc. will be intact.
Tommy if calcfields use these fields the formula will not be updated like this! David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
hi all, we have slightly modified original Object Renumber Tool to renumber fields also. If You are still interested in it, i can send it to You. best regards jem
please send me that.i have lot of objects with lot of fields which have to be renumber.
Best Regards
Uday kumar
