Hi to all,
I have designed a page in page designer and added all the fields and everything seems to be working in designer but when I run the page in RTC it doesnot show some fields like -
I have defined
When I try to run the page in RTC it shows all the fields except . What can be the cause for this kind of problem. Please suggest.
If I define first two fields only then also its not showing the field.
The page is compiled with no errors.
Any suggestion will be helpful.
Thanking you all in advance!
Sangam Shrestha
