Field InvoiceTransRefRecId is empty !
Hello Every One,
I’m working on project that consist of finding all packingSlipId each VendInvoicePosted ,
i found relation between two tables VendinvoiceTrans.Recid =VendPackingSlipTrans.InvoiceTransRefRecId ,
but the probleme was the field InvoiceTransRefRecId is not contains the recId of VendinvoiceTrans , its contains just 0
of all lignes !!
Any help please
Thank you.
Hi Taoufiq,
Even I’m also looking for the same. Did you find any solution for the above?
