Field id issue
I am getting the below error mesasge. Can anyone help me to solve.
The field with ID ‘0’ does not exist in table ‘PurchParmLine’.
Sasi
I think this means a field was deleted from PurchParmLine. Check the debugger where it stops and see the fieldname there. Check if it exists in the AOT.
If yes, Compile the Table and Synchronise. I hope it works. Also compile the class/ table from which the error is thrown. In case of class make a forward compile.
Patrick.
