Field Group Modified Method issue...?
Hi ALL,
I created a Form using Field group of a table.
Now i want to Override a “Modified()”
in a field of That fieldgroup , i wrote and tried its not executing
Tell me your suggessions…
Thanks in Advance…[:)]
Hi Bobby,
You just Override the DS-> Field-> MOdified()
This is executing.
Best Wishes
Hi Suni,
Yes you are correct thats working DS–> Field–>Modified()
But i want to write Modified() only in Designs–>FieldGroup–>Field–>Modified
as per my requirement…
You cannot change the properties when you are directly using a field group from the table - even the methods will not work, because of the AutoDataGroup property set to yes - if you want these to happen change the property to No.But when you add new field to the field group or do any changes to the group at table level - those things will not get effected in the form automatically.
If it is data source field - it is always suggested to write these kind of methods at table level - if not possible at least try to write them at data source level.
Hi Kranthi,
Thank you its working for me.
