I Have created a form in that form i have a String Edit Fireld.
Now in that field i will enter one salesId number. now below i have a grid of salesid and itemid fields form SalesLine Table_DS
according to the entered SalesId value in String Edit Field i want to display SalesLine.SalesId and SalesLine.Itemids
in the Grid…
Share your Ideas…
Thanks In Advance…[:)]
Add a range to the data source - pass the string as range value in the executeQuery() method of the form data source…
Hi Kranthi,
Thanks for Reply
Can u tell me ExecuteQuery ();
my Sting Edit Field Name is “StringEdit_CustPO”
DS Name : SalesLine
Look into InventQuarantine Order form.
See init method of the data source - how the status is added as a range to the Data Source.
See ExecuteQuery() method - how the value is given to the range…(based on that value the records will be filtered)
