Hi! We are using standart Navision CRM functionality to send faxes (via Word MailMerge & Outlook & MS Fax). Is it possible to create deferred faxes from navision? I mean, send fax not immediately, but at night when discounts are available? I has inspecting Word automation objects, but not found any property, where i can set time, when to send fax. Oleg.
Hi, You can schedule Fax codeunit (as you mentioned you are using Navision CRM functionality to send Fax) in Job Schedular available under Service Management->Periodic Activities->Job Scheduler Management
