Fatal internal error
Hi…
Has anyone of you encountered the FATAL Internal error when you attached Crystal reports in NAV?
As mentioned, when we attach the crystal reports in NAV, we copy the location of the file in the C/Al code of the form to where the crystal will be attached. then we compile it and close the designer window. before we entirely close the designer window we are asked if we want to save the changes we made. However, before you could click YES. this error prompts and closes the entire program. so you have to log-in again and start the process all over again.
I have tried researching about this error but to no avail.
hope you could help…
Thanks!:smiley:
Hi Kristine,
Is Nav installed on the PC as opposed to the client directory being copied?
Can you post the code that is causing the error.
