I Tired to add few new field in my sales line table and after i add it in object design → salesline Table → Design
and compiled with no error. But user facing the following error while they doing posting. Anything i forgot to change? or anyway to define the field to accept NULL value?
Ok. But back to the basics then. Navision does not accept NULL values at all. Not even in version 4.
So exactly how does this error happen? You write “user facing the error”, is it only one user?
Also in which content does the error happen? When using one specific form, all forms and even if you just run the table?
Or when using a different way to enter data into Navision?
Hi Erik,
Yeah… i am adding a new field. not one user but all user cannot doing posting that involve sales line table. All forms that involve this “sales line” table cannot be use if i enable the new field that i added.
anywhere to put the empty or initial value (with 0 as empty value) in Navision?
Technically this error should not be happening, no matter the NotBlank property or not.
Fields in Navision SQL can NOT be NULL. In Navision fields can be Blank, but Blank and NULL is not the same.
So I really have no idea. But I would try solve it by trying to isolate the error. If it happens by all users, is it a “techncial” problem or what could it be?.
Could it be related to the SQL database. Are you doing this “in production”??
What happens in your test environment when you do the same? Does it happen in a different company?
What if you create another datatime field? Does the same then happen?
Did you previously have a field with the same name in the same SQL table?
Hi Erik,
Yeah… i rather to leave the data to blank data… but… i seems like system is defined it as NULL… It drive me crazy…
Yes, i am doing this in production.
I don’t have test environment… that’s the biggest issue for me now…
I created 5, same thing happened.
-Yeap, but different table.
Yes development in production could potentially cost the lift your your database! It sure sounds like there is something wrong with the SQL database.
If you don’t have a test environment, then its about time that you get one. You are not getting closer to a resolution, by staying in production.
Also (this is also a long shot), if you still see the problems in a test copy, then try to upgrade to NAV 4.0 SP3.
