Hi
I’m in the process of building BI solution for DAX users.
Is it possible to view a external sharepoint portal link from Dynamics AX?
I have the following requirement
Create a External CUBE in SQL SERVER & Create SSRS reports
(from a DB which is outside DAX) -
Access the CUBE/SSRS report from Sharepoint service and present in Sharepoint portal
Call the Sharepoint portal from Dynamics AX
Dynamics AX user should be able to save user parameters,query etc…
I’m not sure about the third & fourth ones.
I would appreciate if anyone assist me on this.
Technology : MS Dynamics Ax2009 , Sharepoint 2010, SQL Server 2008 R2
Jaffar
