I am using ax 2012 R3.
static void LearningPDF(Args _args)
args args = new args();
CustInvoiceJour custInvoiceJour;
SRSPrintDestinationSettings printSettings;
SalesInvoiceController controller = new SalesInvoiceController();
SalesInvoiceContract salesInvoiceContract;
select firstOnly custInvoiceJour;
args.record(custInvoiceJour);
controller.parmReportName(ssrsReportStr(SalesInvoice, ReportEE));
printSettings = controller.parmReportContract().parmPrintSettings();
printSettings.printMediumType(SRSPrintMediumType::File);
printSettings.fileFormat(SRSReportFileFormat::PDF);
printSettings.overwriteFile(true);
printSettings.fileName('C:\\Users\\vigneshwars\\Desktop\\New folder\\a.pdf');
controller.DEVparmLockDestinationProperties(true);
controller.parmShowDialog(false);
controller.parmArgs(args);
controller.startOperation();
info('done');
I used this code to export sales invoice as pdf file but I am getting this runtime error - Error executing code: Wrong argument types in variable assignment. From the below line
if(DEVLockDestinationProperties)
DEVfixedprintSettings = this.parmReportContract().parmPrintSettings();
I referred this link and I changed the class SrsPrintMgmtFormLetterController methods as given in the link.
Any leads will be appreciated.
Thanks in advance.
