Hello,
Have a user who goes into the customer ledger entries, then clicks on the Excel export icon and gets the following message.
The Parameter string ’ ’ for the mcrosoft excel program is not valid.
Contact your system administrator.
Any suggestions on cause and resolution ?.
Best is click on Entries Press CTRL+A it will select all the entries
Press CTRL+C and then press CTRL+V on excel sheet.
It will copy the data.
goto :
Administration → IT Administration ->General Setup → Launch Application
check whether EXCEL.EXE is there
64 BIT PC and have checked Launch application which is set to EXCEL.EXE
