I have to export data from AX to .csv file to a specific folder using dialog that have two parameter fromDate and toDate. So when i click on the OK of dialog , the data should be exported to cvs file in specific folder.I will not use or DMF or ssrs report.
You can do such an export with Data Import Export Framework. Why exactly do you insist of implementing data export without the framework built specifically for the same task?
Nevertheless you can always write it by yourself if you really want, as in dark ages before DIXF - with CommaTextIo class or so.
