Exporting AOT and Importing it into Another AX Application Instance....?
I have recently installed AX in my Laptop now i want complete AOT from my Desktop AX Application Instance…
My question is how to Export the Complete AOT and Import it into…?
Thnaks In Advance…
Stop AOS
Go to your Axapta Setup Directory. For ex: C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Name_Of_Your_Current_App (Application on Production Environment)
Copy some Application files (*.aod, *.ahd, *.ald, *.add, *.khd) from layers above the DIS layer (BUS, VAR, CUS, USR) then paste to your new Application Directory.
Start AOS and enjoy your life :slight_smile:
If you are doing a customization on the any layer [lets supposed to say that you are doing the customizations on VAR layer] then go to the application file and search for axVAR.aod, copy that and paste it on the new dynamics ax instance, compile whole application , synchronize tables. and dont forget the labels [*.ald file] if you have created a label file.
