I want to export the data to an excel sheet,over different worksheets using Excel buffer or any other method(If any). I am able to get the data over asingle worksheet but i want the data to spread across multiple worksheets.So,How can i achieve this… Is there any function capable of doing the above… please help me out with this…
But you can add a new function to the Excel-buffer table, in wich you add new sheet to existing workbook.
Can be something like this:
AddSheet()
XlWrkSht := XlWrkBk.Worksheets.Add();
Then you fill in the buffer with data for the 1. sheet, create the sheet and empty the buffer.
Call the new function to have a new sheet added to the workbook.
Fill the buffer with data for the 2. sheet, create the sheet, empty the buffer.
And so on…
CODE:
// OPEN THE EXCEL APPLICATION
CREATE(xlApp);
// ALLOW IT TO BE VISIBLE
xlApp.Visible(TRUE);
// CREATE A WORKBOOK WITH ONLY ONE SHEET (WORKBOOK CANNOT BE CREATED EMPTY)
xlApp.Workbooks.Add(1);
// MAKE THE WORKBOOK ACTIVE
xlBook := xlApp.ActiveWorkbook;
// CREATE THE WORKSHEETS (4 OF THEM) WITHIN THE WORKBOOK, AND NAME EACH ONE ON IT’S WORKSHEET TAB
xlSheetCP := xlBook.Worksheets.Add;
xlSheetCP.Name := ‘Customer Sales - Parts’;
xlSheetIC := xlBook.Worksheets.Add;
xlSheetIC.Name := ‘Inter Company’;
xlSheetCE := xlBook.Worksheets.Add;
xlSheetCE.Name := ‘Customer Sales - Equipment’;
xlSheetMC := xlBook.Worksheets.Add;
xlSheetMC.Name := ‘Major Code 99’;
// Remove the ‘original’ sheet named ‘Sheet1’ - keeping only MY sheets
xlApp.DisplayAlerts(FALSE);
xlSheet := xlBook.Worksheets.Item(‘Sheet1’);
xlSheet.Delete;
// CALL FUNCTION TO SETUP SHEETS
SheetSetup;
SheetSetup function:
// SET THE COUNTER TO BEGIN AT THE FIRST SHEET, AND END AT LAST
i := 1;
x := (xlBook.Worksheets.Count);
// LOOP THROUGH EACH SHEET - OUTPUTTTING COLUMN HEADINGS & FORMATTING
REPEAT
xlSheet := xlBook.Worksheets.Item(i);
xlSheet.Range(‘A3’).Value := ‘Item’;
xlSheet.Range(‘B3’).Value := ‘Description’;
xlSheet.Range(‘C3’).Value := ‘Amount’;
xlSheet.Range(‘C:C’).Columns.NumberFormat := ‘#,##0.00’;
//…AND SO ON AND SO ON
i := i + 1;
UNTIL i > x;
