For exporting the data into excel , I have customized and added a button and am using the assembly:“Microsoft.Dynamics.Ax.Fim.Spreadsheets.Spreadsheet.” to execute the logic.
It works perfect if i run the AX 2012 as " run as admin".
When I open AX either from config file or without “run as admin”, the functionality does not work and no output.
Please suggest a solution or reason why its happening to fix the issue.
Earliest response appreciated.
