Export to excel from NAV with excel group function
Making a report to export to excel from NAV is quite easy.
But does anybody know how the “group” function in excel can be used from NAV.
I want to be able to group in excel so possible to use + to expand some of the information instead to see every thing directly. Example group export:
+1
+2
+3
That can be expanded in excel (standard excel group function):
  • 1
111
112
  • 2
222
222
Hope anybody knows how to do this
After exporting to Excel you should use Range function then use Group function
But what is the C/AL for the group function, do you have an example ?
These aren’t C/AL functions but Excel functions. Aren’t you using Excel automation?
Yes, but which automations - the standard in the exel bufffer. My consultant didn’t find the group type
Inside Excel buffer table you a a global variable called XlRange.
That XlRange is an Excel automation that has group function.
