In our return order form (AX 2009) when the user tries to export using Excel the following error occurs:
“Method ‘add’ in COM object of class ‘Workbooks’ returned error code 0x800A03EC () which means: .”
So far we have run a repair on Excel, reinstalled AX. This seems to be specific to this workstation. Anybody have this issue or have a resolution? Any help is appreciated!!
There are a number of reasons this error is returned from Microsoft Excel – the most common is when the user attempts to write data larger than Excel can handle. For example, if we try to write a string longer than 1024 characters to a cell in Excel, it wiill give you an error. Also try installing sp1 of ax 2009 if not installed.
Hope this helps,
Shantanoo, Barry-Wehmiller International Resources
