I am getting the following error when i try to press (EXCEL) button to export to excel.
Can some one tell me how to fix this issue or what is this problem how can i sort it out.
There is no default style sheet for the program you are exporting to.
Thanks.
Check whether you have any default stylesheets available in talbe 2000000066
To setup or check the setup you need to go into “Administration”, “IT Administration”, “General Setup”, “Manage Stylesheets”.
If there are none, you need to import the ones which you can export from CRONUS database.
Or second option is to run the CRONUS, go to table 2000000066 in the object designer, mark all records, copy to clipboard, open your database and run the same table.
There you just try to paste the records.
Hi kami,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
