How to do the Export the Report into Excel using array??..
Padma
Padma
Hi Padma,
What do you mean by array ?
Is this Classic client or RTC ?
G.
Can you be more clear what problem you are facing…
Mohana i am not facing any problem.This is first time i am trying the Export into Excel using array.I dont have any deep knowledge about arrays.
Padma
Then why do you want to do with Array?
HI
Example of Array;
K=0;
K=K+1;
Array[K] :=Value;
I will use a Array because my value change, If i have 10 value Say 1,2,3…10
so my result of value is for 10 times.
Array[1] := value1;
Array[2] :=value2…etc.
This is one of my task.That’s why i want to do that.
You want us to do your task?
try yourself and let us know what problem you are facing…
Hi Padma This may helpful
http://dynamicsuser.net/forums/p/31675/166416.aspx#166416
Jerome Marshal. J
Check Report 6. That has excel export capability.
g.
Hello Mohana,
i am trying also.Then intermediate i il ask the forum also.If you know tell me otherwise no problem.
Hi Marshal ,
Thanks for your help.
Jerome Marshal. J
This is an example of using the excel buffer…
Documentation()
Paddy Test Excel Report
Customer - OnPreDataItem()
Window.OPEN(
Text001 +
‘@1@@@@@@@@@@@@@@@@@@@@@’);
Window.UPDATE(1,0);
TotalRecNo := Customer.COUNTAPPROX;
RecNo :=0;
TempExcelBuffer.DELETEALL;
CLEAR(TempExcelBuffer);
EnterCell(1, 1, Text000, TRUE, TRUE, FALSE);
Row := 3;
Customer - OnAfterGetRecord()
Row := Row + 1;
EnterCell(Row, 1, “No.”, FALSE, FALSE, FALSE);
EnterCell(Row, 2, Name, FALSE, FALSE, FALSE);
RecNo := RecNo + 1;
Window.UPDATE(1,ROUND(RecNo / TotalRecNo * 10000,1));
Customer - OnPostDataItem()
Window.CLOSE;
TempExcelBuffer.CreateBook;
TempExcelBuffer.CreateSheet(Text000,Text000,COMPANYNAME,USERID);
TempExcelBuffer.GiveUserControl;
EnterCell(RowNo : Integer;ColumnNo : Integer;CellValue : Text[250];Bold : Boolean;Italic : Boolean;UnderLine : Boolean)
TempExcelBuffer.INIT;
TempExcelBuffer.VALIDATE(“Row No.”,RowNo);
TempExcelBuffer.VALIDATE(“Column No.”,ColumnNo);
TempExcelBuffer.“Cell Value as Text” := CellValue;
TempExcelBuffer.Formula := ‘’;
TempExcelBuffer.Bold := Bold;
TempExcelBuffer.Italic := Italic;
TempExcelBuffer.Underline := UnderLine;
TempExcelBuffer.INSERT;
Hi
if your problem solved then please verify the solution
Jerome marshal. J
