I just modified the Grant Card in testing enviornment and wanna export it out and import it into production enviornment. Should I go to Object Designer and select the form and go to File Menu and select export?
That’s a way of doing it - export out the fob from the test & import the fob into the production.
Note: I always like to keep a copy of the original one around JUST IN CASE. so export the fob from the live system and keep it safe before overwriting with the new “hopefully tested” one.
