Chars will be exported has default language for non Unicode (DOS codepage) defined in Windows control panel. That code page in general isn’t recognized by Excel and other applications. You must convert code page of file other code page. Window applications that can read correctly this kind of codepages are WordPad (not notepad) and Microsoft Access. If can also convert code page using this tool available in download section: http://dynamicsuser.net/files/folders/nav_tools/entry84404.aspx
Thanks for the reply, actually it does not appear good in wordpad or Access as well.
For your information here is below some information that could help to identify the issue. What do you think?
New TEST Servers:
SQL server fedk0289: SQl server General Server properties: Latin1_General_CI_AS
Windows OS Code page for fedk0289: Language for non unicode programs is English (UK). Code page for conversion tables are all ticked (code page 850 is present).
Navision Collation: Windows Collation - Danish Norwegian’ case-sensitive, accent-sensitive. ‘Validate Code Page’ is uncheck.
Current PROD servers:
SQL server fedk0060: SQl server General Server properties: SQL_Scandinavian:CP850_CS_AS
Windows OS Code page for fedk0060: ???
Navision collation: SQL collation - Scandinavian sort order, code page 850, case sensitive.Validate Code Page’ is uncheck.
