Hello!
I’m new here, and I’m new to with NAV. I need help to export an object using a Blob data type. I’ve try some things like
tempBlob.Modify;
tempBlobCALCFIELDS(Blob);
tempBlob.Blob.Export(‘object.fob’, TRUE);
or
CALCFIELDS(“Obj. Blob Reference”);
“Obj. Blob Reference”.EXPORT(FORMAT(“Obj. Type”) + FORMAT(“Obj. Object ID”));
But it don’t works. And with the first block of code the NAV show this ERROR “ The Export() methd is obsolete.” I make this faction in an Action.
Someone can help me?
Thanks [:)]
You need to remove the second parameter in EXPORT function but I think it’s more practical to use BLOBExport function of codeunit 419.
I remove the second parameter in the Export function and have this error
“Either the caller does not have the required permission or the specified path is read-only”
Someone know how i fixe it? Thanks!
In Export command make sure you specified a complete path which can be written.
In your example the directory is missing, you just stated the file name; moreover remember that if you are running RTC the directory is intended on NST.
when i specify the path it show the same ERROR.
