Export Classic Report to PDF from RTC in background
I am using 2009 SP1 and want to create PDF files for a classic report in background.
I used Bullzip printer and coded a dummy report and it runs fine in classic mode.
However when it comes to RTC, i use the same report it will prompt out the Bullzip Save as screen.
How can i remove this save as screen and auto save to background?
In RTC there is direct option available to export report in PDF format.
Welcome to DUG
You can try this blog post
http://mibuso.com/blogs/mohana/2011/02/20/file-export-in-rtc-with-%e2%80%9ccommon-dialog-management%e2%80%9d/
or there is a function called SAVEASPDF, check the function also
http://msdn.microsoft.com/en-us/library/dd301166.aspx
Hi Mohana
I tried to use SaveAsPDF function but it won’t work when i am using a report that has Classic version only and i get the same message as in the second link.
Here is the message when i use that report in RTC:
The layout of this report has not been transformed to be viewed in the RoleTailored Client. You can run this report in The Microsoft Dynamics NAV classic version.
As i do not have RDLC for this report (just only have Classic version).
Then Please upgrade your report to rdlc…
