I exported No.50010 report. to file rpt50010.fob ,whether import report to No.50010 from rpt50010.fob only or not[?] can I import to another No. example for No.50011 from rpt50010.fob[?]
Hi Peter, as far as I know it is not possible with a *.fob file. But you can do either - export as a txt (if you have developer license) and change the report ID from 50010 to 50011, then import it. - open the report 50010 and change the properties ID (50010 to 50011) and Name (different name than Report 50010) and save it. Then export it again. Regards Walter
Walter, Test success, Good method. thank you
