Expected Cost not clearing
Simple question…should the “Cost Amount (Expected)” on an item ledger entry be cleared once the entry has been fully invoiced?
I know this value is based on the value entries, and so I guess I am asking whether the expected cost entry in the value entry table is deleted/removed once the item ledger entry has been fully invoiced.
We have a situation where several ILE’s have identical values in the expected & actual cost fields and I wonder if this is why we are getting strange results from the inventory valuation report…
By the way, its 3.60 objects on 3.70 client.
Many thanks
Simon
Problem solved - nothing to do with expected cost at all.
The total sum of invoiced quantity for each ILE from the value entry table was double that of the invoiced quantity for the actual ILE itself.
