Expanding 2.00
Hi! on expanding a 2.00 Navision DB from 10 to 12 gb, should i have to stop the service and do this operation locally, or can i expand it using the service? thanks in advance!
Hi Daniele, You can expand the database while the server is running. There is a utility in the client for doing this. I would suggest however that, a) You do this while others are not using the system and b) You run a full Navision backup before doing the expand. That way if Navision crashes while the database is expanding and the file is corrupted, you have a copy to go back to. Hope this is of help.
thanks!
