Is there any possibility to execute variable files form Navision?
For example: i have a form looking like the windows explorer where i can select a file. with a push on an ‘open-button’ i want to execute the file like a doubleclick in windows. when i select a .wav file, the system should run the mediaplayer or if i select a .mp3 file it should run winamp…
(I know the path and the Filename to execute)
is there any possibility to realize this whitout hardcoding the programms for each filetype?
