Excluding special charachters in the Report output..
In the vendor master we have a name field with contains ‘space’, ‘dot’, and ‘-’.
Bt in the Report output,i want this vendor name field to be shown as excluding above mentioned ‘special characters’.
Kindly give the solution with example of syntax.
Thanking you,
kumuda
You dont even want space also?
Can you tell what did you try?
First of all Will that not differ report output from actual master ??
Why not correct the data on master itself ???
