As you probably have noticed - the blocked checkbox is repeated 3 times for each item - 1 for each module type (Invent, Purch, Sales)
Here is an example of a simple lookup that includes filtering on non-blocked items - but what you have to do is pass on the module it is used it.
client static void lookupItemId(FormStringControl _fc, ModuleInventPurchSales _module)
sysTableLookup sysTableLookup;
Query query;
QueryBuildDataSource queryBuildDataSource;
QueryBuildDataSource queryBuildDataSourceModule;
QueryBuildRange queryBuildRange;
QueryBuildRange qbrBlocked;
//this will disable the filtering on input - you can comment it out
_fc.text("");
sysTableLookup = sysTableLookup::newParameters(tableNum(InventTable), _fc);
sysTableLookup.addLookupfield(fieldNum(InventTable, itemId));
sysTableLookup.addLookupfield(fieldNum(InventTable, itemName));
query = new Query();
queryBuildDataSource = query.addDataSource(tableNum(InventTable));
//this sorts the inventory based on the name of items - mostly what users ask to do all the time
//can comment it out too
queryBuildDataSource.addSortField(fieldNum(InventTable, ItemName));
queryBuildDataSourceModule = queryBuildDataSource.addDataSource(tableNum(InventTableModule));
queryBuildDataSourceModule.addLink(fieldNum(InventTable, ItemId), fieldNum(InventTableModule, ItemId));
queryBuildDataSourceModule.addRange(fieldNum(InventTableModule, ModuleType)).value(queryValue(_module));
queryBuildDataSourceModule.addRange(fieldNum(InventTableModule, Blocked)).value(queryValue(NoYes::No));
//this will show you the formed query
// info(queryBuildDataSource.toString());
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
I guess after reading this code you won’t have any problem modifying the form InventItemIdLookupSimple
The InventTable form has to be modified similarily, (the datasources are already there), as faonly you will have to add a checkbox or something on the form and then check it's value on execute query and modify the range of blocked field
