Exchange rate not on order
I’m affraid you are both wrong
There is no “…” on the sales header
There is no filed in either salesLine nor SalesTable called CurrencyFactor or Factor
I do not thinkg you understund the question, yes in AX client there is no problem finding a currecny rate but if you are trying to retrive the data from outside AX, let say from Reporting services or a sql prompt.
Many thanks!
