Exchange rate issue
We have operations in Japan, and we update the exchange rate once a month at month end. Since there is a 20-hour time difference between Japan and US, if I update exchange rate on the 1st day of US time, will this affect the operation? Note that when I update it on the 1st of US time, Japan has already done with 1st day’s invoicing. Please help. thank you.
Hi Raena,
The exchange rate does normally not have any direct affect on the operation as such. And as long as you use correct posting dates, then the only effect is that your new documents/posting is using the new exchange rate.
For the changes to have any direct affect, then you also need to run the adjust exchange rates job.
