I have installed DMF services,DMF AOS and Client on separate server. While I am opening the parameter form following error are occurs
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Configuration.ConfigurationErrorsException: The value of the property ‘address’ cannot be parsed. The error is: Invalid URI: The hostname could not be parsed. (C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAXDEV\Bin\Microsoft.Dynamics.AX.Framework.Tools.DMF.ServiceProxy.dll.config line 12)
at System.Configuration.ConfigurationElement.get_Item(ConfigurationProperty prop)
at System.ServiceModel.Configuration.ChannelEndpointElement.get_Address()
at Microsoft.Dynamics.AX.Framework.Services.Client.Configuration.CustomConfigurationChannelFactory.UpdateServiceEndpoint(ServiceModelSectionGroup group, ChannelEndpointElement selectedEndpoint, ServiceEndpoint serviceEndpoint)
at Microsoft.Dynamics.AX.Framework.Services.Client.Configuration.CustomConfigurationChannelFactory`1.CreateDescription()
at System.ServiceModel.ChannelFactory.InitializeEndpoint(String configurationName, EndpointAddress address)
— End of inner exception stack trace —
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, Object[] args)
at Microsoft.Dynamics.IntegrationFramework.ServiceReference.GetServiceEndpoint(Type serviceClientType, String configFilePath)
at Microsoft.Dynamics.IntegrationFramework.ServiceReference.CreateServiceClient(Type serviceClientType, String configFilePath)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.Dynamics.AX.ManagedInterop.ClrBridgeCore.InvokeClrStaticMethod(Char* pszClassName, Char* pszMethodName, Char* assemblyName, Int32 argsLength, ObjectWrapper** arguments, Boolean* argsAreByRef, Boolean* isException).
Please help me to solve this problem
Thanks in advance
