If Name <> ‘’ then
Sheetname := Rec_ExcelBuffer.SelectSheetsNameStream(NVInStream)
else
exit;
The bold highlighted one throw below error. Can any one let me know what wrong with this? This code was working fine earlier. I am kind of clueless any suggestion please
I have solved the problem if anyone else still has it.
The problem is not with the procedure call, but with the Record Excel Buffer. You have to declare this as temporary. Accordingly, the procedures must be adapted when passing parameters.
In my case, the function must be adapted when evaluating.
Ex:
Evaluate(OrderNo, GetValueAtIndex(RowNo, 1)); call GetValueIndex from : local procedure GetValueAtIndex(RowNo: Integer; ColNo: Integer): Text
var
Rec_ExcelBuffer_Loc: Record "Excel Buffer";
begin
Rec_ExcelBuffer_Loc.Reset();
If Rec_ExcelBuffer_Loc.Get(RowNo, ColNo) then
exit(Rec_ExcelBuffer_Loc. "Cell Value as Text");
end;
change to :
var
begin
Rec_ExcelBuffer.Reset();
If Rec_ExcelBuffer.Get(RowNo, ColNo) then
exit(Rec_ExcelBuffer. "Cell Value as Text");
end;
var
Rec_ExcelBuffer: Record "Excel Buffer" temporary;
