I import the excel data file in AX 2009 . But when i check in preview in Table setup it prompt error “Excel Workbook language differ from current language”.
But i declared language (#DEF) EN-US only, Excel data also contain english only.
I used functional side not in coding side. In Adminstration module → Definition export/import → Definition group. error prompt in preview tab(before import usually i check this)
This issue is coming only for the latest excel file. if i try in other excel files it’s working fine(for same table).
