I Need to create a NAV Report that does the following.
Step 1. Shows all BALANCE SHEET Accounts and BALANCE AT Figures
Step 2 Shows all General Ledger entries.
How would you go about this given that I have a report that does step 2.
Thank you in advance.
A
You can put filter in Chart of Accounts on Income/Balance and filter for Balance Sheet and put a date filter till which date balance is required. and copy/export to excel.
You will get the report.
Yes I understand thank you but the following is true / needs to take place.
The Spreadsheet needs to detail separately Balance Sheet and Income Statement Accounts / transactions as follows:
Balance Sheet Accounts
Account No Balance At Date
XXXX xxxxxxxxxxxxxx
Income Statement
Various G/L Entry Detail----------------------------------------------------
Can I incorporate detail from the G/L Card and G/L entry table in such a way using Excel export.
Hope this makes sense.
A
You mean to say the report should contain the Account No followed by the transactions .
You need to customize the report or you need to pick up entries manually from system and paste it in excel.
This can be achieved by Detail Trail Balance Report(Standard Report- Id =4) by applying the filter
Income/Balance field = Balance Sheet.
It will show the account details as well as GL entries of that account.
Regards
Bheem Singh
