Excel Range :: Please help :: urgent
Can anybody please help with any idea about export of excel in x++ with more than 256 columns having some values
when reading an excel with Sys excel classes.
SysRange object should return excel with more than 256 columns having values.
thou, it only returns 256 cloumn excel even if there are 1000 columns in excel while reading it.
Or, do i need to make change in some excel macros?
Please help…
Geetika
try this sample code below.
static void excel(Args _args)//SKO
SysExcelApplication xlsApplication;
SysExcelWorkBooks xlsWorkBookCollection;
SysExcelWorkBook xlsWorkBook;
SysExcelWorkSheets xlsWorkSheetCollection;
SysExcelWorkSheet xlsWorkSheet;
SysExcelStyles styles;
SysExcelStyle style;
SysExcelFont font;
SysExcelCells cells;
ComVariant _template;
int row = 1;
str endString;
VendTable vendTable;
FileName fileName = “C:\New folder\Test.xlsx”;
//adding worksheets
xlsApplication = SysExcelApplication::construct();
xlsWorkBookCollection = xlsApplication.workbooks();
xlsWorkBook = xlsWorkBookCollection.add(_template);
xlsWorkSheetCollection = xlsWorkBook.worksheets();
xlsWorkSheet = xlsWorkSheetCollection.itemFromNum(1);
//Adding columns to the row.
for (row = 1; row < 4; row++)
if(row == 1)
xlsWorkSheet.cells().item(row, 1).value(’’);
xlsWorkSheet.cells().item(row, 2).value(’’);
xlsWorkSheet.cells().item(row, 3).value(’’);
xlsWorkSheet.cells().item(row, 4).value(’’);
xlsWorkSheet.cells().item(row, 5).value(’’);
xlsWorkSheet.cells().item(row, 6).value(’’);
xlsWorkSheet.cells().item(row, 7).value(’’);
xlsWorkSheet.cells().item(row, 8).value(’’);
xlsWorkSheet.cells().item(row, 9).value(’’);
xlsWorkSheet.cells().item(row, 10).value(’’);
xlsWorkSheet.cells().item(row, 11).value(’’);
xlsWorkSheet.cells().item(row, 12).value(’’);
xlsWorkSheet.cells().item(row, 13).value(’’);
xlsWorkSheet.cells().item(row, 14).value(’’);
xlsWorkSheet.cells().item(row, 15).value(’’);
xlsWorkSheet.cells().item(row, 16).value(’’);
xlsWorkSheet.cells().item(row, 17).value(’’);
xlsWorkSheet.cells().item(row, 18).value(’’);
xlsWorkSheet.cells().item(row, 19).value(’’);
xlsWorkSheet.cells().item(row, 20).value(’’);
xlsWorkSheet.cells().item(row, 21).value(’@FTD1’);
xlsWorkSheet.cells().item(row, 25).value(’@FTD5’);
xlsWorkSheet.cells().item(row, 31).value(’@FTD405’);
xlsWorkSheet.cells().item(row, 45).value(’@FTD405’);
xlsWorkSheet.cells().item(row, 52).value(’@FTD337’);
xlsWorkSheet.cells().item(row, 62).value(’@FTD338’);
xlsWorkSheet.cells().item(row, 83).value(’@FTD217’);
xlsWorkSheet.cells().item(row, 87).value(’@FTD220’);
if(row == 2)
xlsWorkSheet.cells().item(row, 21).value(’@FTD406’);
xlsWorkSheet.cells().item(row, 22).value(’@FTD406’);
xlsWorkSheet.cells().item(row, 23).value(’@FTD406’);
xlsWorkSheet.cells().item(row, 24).value(’@FTD406’);
xlsWorkSheet.cells().item(row, 25).value(’@FTD407’);
xlsWorkSheet.cells().item(row, 27).value(’@FTD407’);
xlsWorkSheet.cells().item(row, 29).value(’@FTD407’);
xlsWorkSheet.cells().item(row, 62).value(’@FTD211’);
xlsWorkSheet.cells().item(row, 66).value(’@FTD408’);
xlsWorkSheet.cells().item(row, 70).value(’@FTD408’);
xlsWorkSheet.cells().item(row, 74).value(’@FTD409’);
xlsWorkSheet.cells().item(row, 78).value(’@FTD214’);
xlsWorkSheet.cells().item(row, 83).value(’@FTD351’);
xlsWorkSheet.cells().item(row, 85).value(’@FTD352’);
if(row == 3)
xlsWorkSheet.cells().item(row, 1).value(’@FTD319’);
xlsWorkSheet.cells().item(row, 2).value(’@FTD32’);
xlsWorkSheet.cells().item(row, 3).value(’@FTD322’);
xlsWorkSheet.cells().item(row, 4).value(’@FTD2’);
xlsWorkSheet.cells().item(row, 5).value(’@FTD321’);
xlsWorkSheet.cells().item(row, 6).value(’@FTD320’);
xlsWorkSheet.cells().item(row, 7).value(’@FTD83’);
xlsWorkSheet.cells().item(row, 8).value(’@FTD323’);
xlsWorkSheet.cells().item(row, 9).value(’@FTD324’);
xlsWorkSheet.cells().item(row, 10).value(’@FTD325’);
xlsWorkSheet.cells().item(row, 11).value(’@FTD299’);
xlsWorkSheet.cells().item(row, 12).value(’@FTD403’);
xlsWorkSheet.cells().item(row, 13).value(’@FTD173’);
xlsWorkSheet.cells().item(row, 14).value(’@FTD327’);
xlsWorkSheet.cells().item(row, 15).value(’@FTD86’);
xlsWorkSheet.cells().item(row, 16).value(’@FTD328’);
xlsWorkSheet.cells().item(row, 17).value(’@FTD329’);
xlsWorkSheet.cells().item(row, 18).value(’@FTD330’);
xlsWorkSheet.cells().item(row, 19).value(’@FTD331’);
xlsWorkSheet.cells().item(row, 20).value(’@FTD388’);
xlsWorkSheet.cells().item(row, 21).value(’@FTD389’);
xlsWorkSheet.cells().item(row, 22).value(’@FTD390’);
xlsWorkSheet.cells().item(row, 23).value(’@FTD391’);
xlsWorkSheet.cells().item(row, 24).value(’@FTD392’);
xlsWorkSheet.cells().item(row, 26).value(’@FTD358’);
xlsWorkSheet.cells().item(row, 27).value(’@FTD5’);
xlsWorkSheet.cells().item(row, 28).value(’@FTD358’);
xlsWorkSheet.cells().item(row, 29).value(’@FTD5’);
xlsWorkSheet.cells().item(row, 30).value(’@FTD358’);
xlsWorkSheet.cells().item(row, 31).value(’@FTD202’);
xlsWorkSheet.cells().item(row, 32).value(’@FTD393’);
xlsWorkSheet.cells().item(row, 33).value(’@FTD204’);
xlsWorkSheet.cells().item(row, 34).value(’@FTD419’);
xlsWorkSheet.cells().item(row, 35).value(’@FTD397’);
xlsWorkSheet.cells().item(row, 36).value(’@FTD396’);
xlsWorkSheet.cells().item(row, 37).value(’@FTD398’);
xlsWorkSheet.cells().item(row, 38).value(’@FTD399’);
xlsWorkSheet.cells().item(row, 39).value(’@FTD349’);
xlsWorkSheet.cells().item(row, 40).value(’@FTD400’);
xlsWorkSheet.cells().item(row, 41).value(’@FTD350’);
xlsWorkSheet.cells().item(row, 42).value(’@FTD401’);
xlsWorkSheet.cells().item(row, 43).value(’@FTD334’);
xlsWorkSheet.cells().item(row, 44).value(’@FTD18’);
xlsWorkSheet.cells().item(row, 45).value(’@FTD420’);
xlsWorkSheet.cells().item(row, 46).value(’@FTD410’);
xlsWorkSheet.cells().item(row, 47).value(’@FTD411’);
xlsWorkSheet.cells().item(row, 48).value(’@FTD412’);
xlsWorkSheet.cells().item(row, 49).value(’@FTD413’);
xlsWorkSheet.cells().item(row, 50).value(’@FTD414’);
xlsWorkSheet.cells().item(row, 51).value(’@FTD336’);
xlsWorkSheet.cells().item(row, 52).value(’@FTD205’);
xlsWorkSheet.cells().item(row, 53).value(’@FTD415’);
xlsWorkSheet.cells().item(row, 54).value(’@FTD347’);
xlsWorkSheet.cells().item(row, 55).value(’@FTD416’);
xlsWorkSheet.cells().item(row, 56).value(’@FTD348’);
xlsWorkSheet.cells().item(row, 57).value(’@FTD417’);
xlsWorkSheet.cells().item(row, 58).value(’@FTD349’);
xlsWorkSheet.cells().item(row, 59).value(’@FTD418’);
xlsWorkSheet.cells().item(row, 60).value(’@FTD350’);
xlsWorkSheet.cells().item(row, 61).value(’@FTD401’);
xlsWorkSheet.cells().item(row, 62).value(’@FTD321’);
xlsWorkSheet.cells().item(row, 63).value(’@FTD402’);
xlsWorkSheet.cells().item(row, 64).value(’@FTD359’);
xlsWorkSheet.cells().item(row, 65).value(’@FTD403’);
xlsWorkSheet.cells().item(row, 66).value(’@FTD321’);
xlsWorkSheet.cells().item(row, 67).value(’@FTD402’);
xlsWorkSheet.cells().item(row, 68).value(’@FTD359’);
xlsWorkSheet.cells().item(row, 69).value(’@FTD403’);
xlsWorkSheet.cells().item(row, 70).value(’@FTD321’);
xlsWorkSheet.cells().item(row, 71).value(’@FTD402’);
xlsWorkSheet.cells().item(row, 72).value(’@FTD359’);
xlsWorkSheet.cells().item(row, 73).value(’@FTD403’);
xlsWorkSheet.cells().item(row, 74).value(’@FTD321’);
xlsWorkSheet.cells().item(row, 75).value(’@FTD402’);
xlsWorkSheet.cells().item(row, 76).value(’@FTD359’);
xlsWorkSheet.cells().item(row, 77).value(’@FTD403’);
xlsWorkSheet.cells().item(row, 78).value(’@FTD321’);
xlsWorkSheet.cells().item(row, 79).value(’@FTD402’);
xlsWorkSheet.cells().item(row, 80).value(’@FTD359’);
xlsWorkSheet.cells().item(row, 81).value(’@FTD403’);
xlsWorkSheet.cells().item(row, 82).value(’@FTD334’);
xlsWorkSheet.cells().item(row, 83).value(’@FTD360’);
xlsWorkSheet.cells().item(row, 84).value(’@FTD361’);
xlsWorkSheet.cells().item(row, 85).value(’@FTD360’);
xlsWorkSheet.cells().item(row, 86).value(’@FTD361’);
xlsWorkSheet.cells().item(row, 87).value(’@FTD353’);
xlsWorkSheet.cells().item(row, 88).value(’@FTD15’);
xlsWorkSheet.cells().item(row, 89).value(’@FTD7’);
xlsWorkSheet.cells().item(row, 90).value(’@FTD8’);
xlsWorkSheet.cells().item(row, 91).value(’@FTD355’);
xlsWorkSheet.cells().item(row, 92).value(’@FTD13’);
xlsWorkSheet.cells().item(row, 93).value(’@FTD356’);
xlsWorkSheet.cells().item(row, 94).value(’@FTD404’);
xlsWorkSheet.cells().item(row, 95).value(’@FTD16’);
xlsWorkSheet.cells().item(row, 96).value(’@FTD339’);
//Adding header
styles = xlsWorkBook.styles();
style = styles.add(‘Header’);
//Adding font description
font = style.font();
font.bold(true);
xlsWorkSheet.rows().item(row).style(‘Header’);
//row++;
xlsWorkSheet.columns().autoFit();
cells = xlsWorkSheet.cells();
xlsWorkBook.saveAs(fileName);
xlsWorkBook.comObject().save();
xlsWorkBook.saved(true);
//row = 1;
xlsApplication.quit();
xlsApplication.finalize();
