Excel Line Limit when exporting from Nav
Does anyone know if there is a line limit when exporting an analysis view from Nav to Excel. Although I am on Excel 2007 with over 1 million rows allowed, the Nav export is erroring stating that Excel is limited to 65000 rows.
I have exported the data manually and then setup a pivot table on 200,000 rows from this text and this works, so it not an excel issue.
Any help would be most appreciated
Andrew
Hi Andrew,
Check Codeunit 424
IF NoOfRows > 65000 THEN
ERROR(Text032,65000,AnalysisView.FIELDCAPTION(“Date Compression”),AnalysisView.TABLECAPTION);
Hope this helps
Albert
Thats great.
Thanks very much
Andrew
If you go to Tools - Options - Under Max. no. of XML records put in a higher number and it should work.
