Is it possible to do excel import (using SysExcelApplication) in Sysoperation framework where the service class runs on server ?
Thanks & Regards,
Chutti
Thanks & Regards,
Chutti
It is possible to use SysOperation framework for it, but it’s not possible to do it in server-only session (such as in batch) nor CIL, because SysExcelApplication class must run on client.
Thank you Martin
Detailed explanation here…
www.technograffito.com/import-data-from-excel-using-sysOperation-framework-ax-2012
