We have a client who when they use the excel export button, it generates a text format file in excel.
They are using 5.0 SP1.
Does anyone have any ideas/solutions to this problem
Any help would be much appreciated
Andrew Cooper
Andrew Cooper
Hi Andrew,
Did you check the file that is created? It may be a Excel saved as a .txt.
Are you getting this from a standard export or is it a custom export?
Its just the standard export function, using the quick button on the tool bar, so doesn’t save, it just creates a sheet.
Andrew
Hi Andrew,
Has you check the style sheet in use for the form
Thanks for that, any ideas what we should be checking for in the style sheet?
Hi Andrew,
Have a read of the post in this blog
