Excel calls AIF web service to import sales order
By calling sales order service’s create method, I am able to create sales order from excel cells.
However, I found that the unit price field of the sales line is not set according to my excel input (which is different from the item unit price stated in AX item table) …
Instead, it seems that the service simply ignore my input and just fill in the unit price from searching the item table.
I would like to ask if anyone has such an experience in using salesorder AIF service. Is it possibble to modify the web service class to check and change the unit price setting?
Recently I worked on creating SO in AX from a web (.NET) front end. You should be able to modify the web service class.
