As written in the title, I added a field in the item table and published its “OnAfter Validate” event. I subscribed to this event in another Codeunit where I do several syntax checks.
When entering data through the item card page everything works well but when I enter data trough direct execution of table from object designer the event isn’t fired. Normal OnValidate code is working well.
I often use this possibility to enter manipulate data during development. Is there some constraint for events I did not know?
THank you for fast reply. Some deeper investigation I found that Skip for Permission / License was the issue. I am stil not sure why it worked for Pages and VALIDATE in Import-Report and not for direct opening but after restart of DB Service it worked for all in the same way. I also changed it now to Error.
