Events In AL
I want to add some cusomized logic in Codeunit 80 In AL, but as we can not extend CodeUnit 80 in AL. So I have created a Event Integration(OnBeforePostCommit) added some customized function in Independent customized codeunit. can this work in AL or how we can use Event in AL means publish and Subscribes.
Please give me some suggestion.
Thank You.
Hi Akkrahul,
If you make any customizations in in C/SIDE using C/AL, then you have to rebuild your symbols, before you can see/use the changes from AL.
