I am compiling a codeunit and to compile that I need to delete a variable :
Name DataType Subtype Length
SQLServer Automation Unknown Automation Server.Unknown Class
if I try to delete the variable I am getting a confirmation:
There are event triggers associated to the global variable SQLServer.
Deleting the variable will delete the event triggers and their code
Are you sure that you want to delete this global variable?
I checked variable property: WithEvents it is No.
So where and how can I find these variable events?
