I am looking for a very specific Dynamics Nav add on in the mechanical engineering industry. I would like to know if there are an add on for the engineering to order manufacturer / Job Costing -manufacturing integration in Nav.
Functionalities required are in one solution are;
Estimating/Tendering on a project
Management of off-cuts i.e stock item which can be reused and return to store. Same item code but could be using vairants.
Time collection integration with the workshop floor via a Bar coding. employeeswill record their time against the job via a time collection solution which in turn is integrated with Nav Job costing or manufacturing.
Allocation of overhead on projects based on amount or %
Invoicing on job based on agreed billing scheduled or as per QS certification for job delivered.
I will appreciate if someone can advise on the above Nav Add on or else this means what I will have to develop it.
Version RTC.
Thanks.
