Errorr:-A parameter could not be serialized.
During Posting Purchase Order in Ax2012 …
I am New in Ax2012 Pls let me knw…
IF any sloutions…]
Thnks in Advance
IF any sloutions…]
Thnks in Advance
Hi Manas,
This is most likely due to customization that has gone wrong. You would need a developer to find out cause and fix this issue.
Hi Harish Instance is newly created no any customisations are there …
am working on client …
For a quick resolve: uncheck option “Excute business operations in CIL” under Tools-> Options → Development tab.
Rather you should run the FULL CIL
Vinoth Kanna Your Solution worked
Thanks alot
