Hello,
when I run this method from a runbasebatch class I get an exception error in the calling new() method, if I run from Job I get not errors.
Any idea?
from runbasebatch: **LSP_FileManager::writeFileStream(**fileName, content);
server static void writeFileStream(str _fileName, str _content)
System.IO.StreamWriter sw;
InteropPermission perm = new InteropPermission(InteropKind::ClrInterop);
perm.assert();
sw = new System.IO.StreamWriter(_fileName, false);
sw.Write(_content);
sw.Flush();
sw.Close();
sw.Dispose();
CodeAccessPermission::revertAssert();
where _filename is '\se-srv3\mydir\filetest.txt’
and the job:
server static void job15_writefilestream()
str _fileName = @’\Se-srv3*mydir\filetest.txt*’;
str _content =“A”;
perm.assert();
sw.Write(_content);
sw.Flush();
sw.Close();
sw.Dispose();
